    Trying to connect Android Auto to car's Android Auto capable infotainment. The car has a USB C connection while my phone (moto g5 plus) has a micro usb port. Most cables I've tried only charge the phone, but don't connect to android auto. Is there a specific data cord that's Micro USB to USB C for connecting to the infotainment?
    06-24-2020 03:01 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Any cable should work, assuming they're not damaged or specifically charge only (and I doubt there are any charge-only microUSB-to-USB-C cables). When you connect the phone to the head unit, swipe down the notification panel on the phone and tap the USB notification -- make sure it's not set to Charge Only there.
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    06-24-2020 03:26 PM
  3. BUjj's Avatar
    Original Poster here after I registered. The cord I ordered off of Amazon does say charging, but the description mentioned data sync. I even went into the developer options to configure the USB connection to data transfer, but the radio unit still doesn't detect android auto on the phone. Was hoping there's a recommended cord someone has used, Micro to USB C. The car is a GTI.
    06-24-2020 04:17 PM
  4. B. Diddy's Avatar
    Ok, so just to be clear, you did swipe down the notification panel and tap the USB notification to see what kind of connection is selected, right?
    06-24-2020 04:51 PM
  5. BUjj's Avatar
    Yes indeed. I ordered 2 more cables from Amazon to see if they would work, linked below, and should find out tomorrow. Also going to try my wife's Pixel 3a with a USB c to USB c so I'm hoping at least one of those works. Just wasn't sure if there was a recommended brand as recognized by android central as a reliable data transfer cord.
    https://www.amazon.com/gp/product/B0...cUvbUpU6809012
    06-24-2020 05:42 PM
  6. mustang7757's Avatar
    https://www.amazon.com/gp/product/B0...cUvbUpU6809085
    HI, welcome!
    Yeah give that a try see how it works out
    06-24-2020 09:16 PM
  7. BUjj's Avatar
    The cords worked! In fact the provided adapter from VW worked too that originally did not. Apparently I had to reset the car's radio unit to its factory settings, and only then did it fully recognize my phone. So for anyone else who find themselves in a similar vote, reset your radios first before buying up a bunch of cords.
    B. Diddy and mustang7757 like this.
    06-25-2020 12:22 PM
  8. mustang7757's Avatar
    Glad to hear that, thanks for posting back the fix.
    06-25-2020 04:29 PM
  1. Fold 2 instead of the N20 Ultra?
    By j_hansen in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-20-2020, 10:33 AM
  2. Can the charging unit cause loss of network signal?
    Last Post: 06-26-2020, 02:04 PM
  3. Not able to install Facebook Messenger?
    Last Post: 06-25-2020, 05:34 AM
  4. How come when my boyfriend texts me, the number shows twice side-by-side?
    Last Post: 06-24-2020, 09:24 PM
  5. Can I change the icon notification of Google Chrome app?
    Last Post: 06-24-2020, 07:09 PM
