Save big + get 3 months free! Sign up for ExpressVPN today
    I use Asus zenfone max pro M1 (andorid 9). I have got battery of 5000mAh on my phone, so I had been enjoying a long screen usage (12+ hrs on an average) and last full charge would be (30 hrs+ ) before it hit 15% mark. Recently it has been draining battery at an astonishing rate. Phone wouldn't last more than 12 hrs in total and screen usage would be a maximum of 6-8 hrs. I have Netflix, prime, YouTube, Facebook, whatsapp etc apps that have massive drains. But I have not been using the OTT platforms for a while and my data and wifi connection is off when not using it. I close the apps when they are not in use. i definitely close all the apps when I go to sleep. I have tried factory resetting my phone, didn't work. Tried rebooting and replacing suspicious apps. Nothing works.
    06-26-2020 01:12 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which may show Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html.
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    Laura Knotek and VidJunky like this.
    06-26-2020 02:16 AM
  3. mustang7757's Avatar
    I would try safe mode, sounds like a 3rd party app causing this
    06-26-2020 08:43 PM
  4. anon(10696963)'s Avatar
    This is my battery usage and other information you asked for
    Attached Thumbnails My phone battery is draining 30% overnight?-screenshot_20200628-000828.jpg   My phone battery is draining 30% overnight?-screenshot_20200628-000820.jpg   My phone battery is draining 30% overnight?-screenshot_20200628-000812.jpg   My phone battery is draining 30% overnight?-screenshot_20200628-000804.jpg   My phone battery is draining 30% overnight?-screenshot_20200628-000747.jpg
    06-27-2020 01:44 PM
  5. B. Diddy's Avatar
    Were you using Hotstar this much before? Also, it'd still be helpful to see what your cell signal has been like, since poor signal can increase battery drain. GSam Battery Monitor is the easiest way to see your cell signal over time.
    06-27-2020 02:26 PM
  6. mustang7757's Avatar
    Hot star is high up there, but there got be more to this
    06-27-2020 02:44 PM
  7. anon(10696963)'s Avatar
    Should I charge it to 100% again and then again collect data at 20-30% or is it fine at the current state of (73%)?
    Also I don't use hotstar that frequently because rarely it has things to binge watch or a movie worth watching, but an hour of Netflix episode would cost me 10% battery. I am not sure about hotstar but it definitely wasn't this heavy. It costs me almost 30% for 1 hr right now.
    06-28-2020 12:30 AM
  8. B. Diddy's Avatar
    Try uninstalling Hotstar temporarily and see if the battery drain persists.
    06-28-2020 11:04 AM
  9. cardboard60's Avatar
    I agree, Uninstall hotstar.
    Run itbdowb to 25%
    Charge it ton100% several.times
    Don't be skeered to abuse the battery.
    Don't baby it.
    06-28-2020 04:59 PM
  10. cardboard60's Avatar
    I charged my note 10+ last nite To 100%.
    I always charge it to 100%
    Picked it up off charger at 9:00 to go in the bedroom and watch TV.
    I have a flat samsung charger.
    Never used it after 9:00pm
    Got up this at 5:00am to drink coffee.
    Got the battery % meter on my phone turned on to show what percentage the battery was at 97%
    I think I had a good nite.
    06-29-2020 05:03 AM
  11. mustang7757's Avatar
    So have you uninstall hotstar and been ok ?
    06-29-2020 11:25 PM
  12. anon(10696963)'s Avatar
    Uninstalled hotstar, no difference
    06-30-2020 01:50 AM
  13. B. Diddy's Avatar
    You said you're turning off your mobile data overnight -- are you also turning on Airplane Mode? It'd still be helpful to see your cell signal strength in case poor signal is contributing to the drain.
    06-30-2020 10:51 AM
  14. cardboard60's Avatar
    Turn it on Do not disturb
    06-30-2020 12:42 PM
  15. Kaustubh Dwivedi1's Avatar
    change your battery bescaus im also facing same problem until i change my battery and use only stock charge and cable and original asus battery
    08-11-2020 10:19 AM
  1. Is there any information about the S20 Lite?
    By KaiZon in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 06-30-2020, 11:11 PM
  2. Verizon locked phone got an update for Samsung Cloud.
    By felloffthetruck in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 06-28-2020, 08:44 AM
  3. My phone is not turning on?
    Last Post: 06-27-2020, 07:23 AM
  4. Replies: 2
    Last Post: 06-25-2020, 08:32 PM
  5. My S10 stopped fast charging
    Last Post: 06-25-2020, 03:54 PM
