    I am having a Asus x008da (Asus 3 max)
    It is stuck in loading screen.So I decided to Flash it with SP tool Because it is not working with SD Card option and In ADB sideload
    mode my pc is not detecting the device
    I downloaded the firmware from Asus official website And when I loaded the scatter file I got an error
    "ERROR:STATUS_SCATTER_FILE_INVALID(0xC0030001)
    The scatter file format is invalid!
    [HINT]:
    Please Select a valid load or ask for help"
    I tried another firmware from the asus official website but returns the same error
    Plzz Help me.......
    07-19-2020 09:03 AM
  2. mustang7757's Avatar
    First you need the computer to recognize your device, command window you type adb devices ? Is this first time doing this ?
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.https://forums.androidcentral.com/sh...d.php?t=409154
    07-19-2020 10:51 AM
  3. BLACKWIZ's Avatar
    I Had done it one time in another Asus device So I know some basic stuff
    But here the issue is that my PC is not detecting the device in Adb sideload mode even as a unknown device there is no change in my device manager.
    it Detects in fastboot mode So i thought of flashing in fastboot mode
    It will be very help full If you help me
    07-19-2020 11:51 AM
  4. BLACKWIZ's Avatar
    I created the account in android central forums
    07-19-2020 11:52 AM
  5. mustang7757's Avatar
    Hi, welcome to AC!
    Have you tried rebooting the computer or tried different ports ?
    07-19-2020 11:55 AM
  6. BLACKWIZ's Avatar
    ya i tried it
    07-19-2020 11:57 AM
  7. BLACKWIZ's Avatar
    do this issue have anything related to windows (I am having Win10)
    07-19-2020 11:58 AM
  8. mustang7757's Avatar
    Try using this adb and fast boot and run the commands again
    07-19-2020 12:04 PM
  9. mustang7757's Avatar
    Possible, you have another computer to try?
    07-19-2020 12:05 PM
  10. BLACKWIZ's Avatar
    yep
    07-19-2020 12:06 PM
  11. mustang7757's Avatar
    yep
    Could try the other computer first
    07-19-2020 12:07 PM
  12. BLACKWIZ's Avatar
    I tried but no way
    07-19-2020 01:45 PM
  13. mustang7757's Avatar
    I tried but no way
    Doesn't recognize?
    07-19-2020 02:58 PM
  14. BLACKWIZ's Avatar
    Sorry of late reply i had some network issue
    Yea it didn't recognize
    07-20-2020 11:07 PM
  15. mustang7757's Avatar
    The other computer you tried , what windows it was on ? This is your main issue it can't execute a command with file because its not recognizing your device.
    07-21-2020 01:09 AM
  16. BLACKWIZ's Avatar
    windows 8.1 i tried . I can't understand why it is not recognizing the device.
    07-21-2020 01:29 AM
  17. BLACKWIZ's Avatar
    Should I try win 7 ultimate
    07-21-2020 01:30 AM
  18. anon(10614692)'s Avatar
    Try installing ADB drivers https://adb.clockworkmod.com/
    mustang7757 likes this.
    07-21-2020 05:44 AM
  19. mustang7757's Avatar
    Try but install the adb link i mentioned earlier or what Zoo has linked
    07-21-2020 10:40 AM
  20. BLACKWIZ's Avatar
    Windows is not at all detecting
    means IT is not detecting even as a unknown device
    If I plugin the phone it is just like a usb cable connected simply without a device
    There is no respone from both the device If I connect in abd sideload mode
    SO ONLY OPTION IS TO FLASH THROUGH FASTBOOT
    for that i need a sp flash tool supported firmware
    07-22-2020 09:44 AM
  21. mustang7757's Avatar
    Let me ask this , does your computer recognize the device when plugged in ?
    07-22-2020 11:38 AM
  22. BLACKWIZ's Avatar
    No, It is not recognizing in the adb sideload mode
    But recognizes in fastboot mode
    (Device is stuck in boot logo)
    07-22-2020 11:48 AM
  23. mustang7757's Avatar
    Ok that means , cables ,computer are good , sideload mode you need to execute commands and it doesn't recognize that , possible your adb studio or such needs to be reinstall or different version to work . Have you tried the 2 links that was suggested?
    07-22-2020 11:53 AM
  1. Replies: 43
    Last Post: 12-26-2020, 08:06 PM
  2. Wi-Fi 6/AX possible issues.
    By JamesMason580 in forum Ask a Question
    Last Post: 12-06-2020, 07:23 PM
  3. A small charging percentage issue...
    Last Post: 07-20-2020, 10:07 PM
  4. Help with restoring WhatsApp messages from old to new phone?
    By Sim8 in forum General Help and How To
    Last Post: 07-18-2020, 01:05 PM
  5. What spyware do I have? Please HELP.
    Last Post: 07-18-2020, 12:01 AM
