    Hi guys, I've been using my Redmi Note 5 pro for almost two years now, and it has given a consistent good battery backup. But suddenly from yesterday, the battery is draining fast, and android system is taking up 35-36% of the battery. I am hardly getting 5 hours on-screen time. Also my phone constantly remains warm even when not used. I've seem some similar issues been posted on this forum and elsewhere also, but none of the solutions have improved the condition. The things I have tried are:
    clearing cache of all apps, re-updating google play services, rebooting my phone, enabling battery optimization for Xiaomi services framework, killing Chrome process
    Please help me!(And sorry for my English, its not my native language)
    08-11-2020 02:36 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this happen in Safe Mode as well? https://www.getdroidtips.com/boot-re...pro-safe-mode/
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    08-11-2020 08:30 PM
  3. mustang7757's Avatar
    Also force stop andriod system
    08-11-2020 09:54 PM
  4. Mdeflamme's Avatar
    I turned on safe mode, but the battery drain was same. Why is my battery draining so fast on Redmi Note 5 pro?-screenshot_2020-08-12-10-02-05-064_com.miui.securitycenter.jpg
    08-12-2020 01:03 AM
  5. Mdeflamme's Avatar
    I forced stop it and also cleared the cache, but nothing happened.
    08-12-2020 01:04 AM
  6. mustang7757's Avatar
    I turned on safe mode, but the battery drain was same. Click image for larger version.
    You'll have reset the battery usage stats, and monitor next time , to do that is charge to 100% then wait until about 20 percent see if its same
    08-12-2020 01:06 AM
  7. mustang7757's Avatar
    You'll have to monitor it after what I mentioned in post #6
    08-12-2020 01:07 AM
  8. Mdeflamme's Avatar
    It is the same, because the battery was still draining by 1% every 3-4 minutes and the phone was still warm. I kept it in safe mode for 30 minutes. I took the screenshot to show the battery usage, it just happened to be while in safe mode. Is this caused by some google application?
    08-12-2020 01:21 AM
  9. B. Diddy's Avatar
    Considering that this is happening in Safe Mode, it might be time to do a factory reset. If the problem persists after a factory reset, then the battery might be starting to fail. It wouldn't be that unusual at this point in time.
    08-12-2020 01:21 AM
  10. mustang7757's Avatar
    Its possible, agree with B. Diddy if that's still happening.
    08-12-2020 01:24 AM
  1. Note 20 Ultra pre-order UK thread.
    By Kath1404 in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 09-04-2020, 08:38 AM
  2. I purchased a Foren-Tek 10 inch Android Tablet that runs on Android Oreo 8.1.
    Last Post: 08-13-2020, 06:36 PM
  3. I am getting a vertical white straight line when i open my front camera
    Last Post: 08-12-2020, 12:49 PM
  4. Phone is ringing randomly, nobody calling
    Last Post: 08-12-2020, 12:52 AM
  5. Which phone is best bang for buck?
    Last Post: 08-12-2020, 12:36 AM
