    I have tried rebooting, network resetting, airplain mode toggle, nothing works
    08-13-2020 10:08 AM
  2. anon(10614692)'s Avatar
    What carrier are you using?
    08-13-2020 10:13 AM
  3. L0n3N1nja's Avatar
    Is this a new phone or is it a new problem with a phone that was previously working?
    08-13-2020 11:54 AM
  4. B. Diddy's Avatar
    Welcome to Android Central! If the phone doesn't support your carrier's LTE bands, then you won't get LTE. Even if it does support one or two of those bands, you still might not get it if the towers in your areas use different bands.
    Here's a list of the bands it supports: https://www.devicespecifications.com/en/model/d8c25347
    08-13-2020 12:33 PM
  1. My Note 9 reboots often when I sleep...
    By captivedroid in forum Samsung Galaxy Note 9
    Last Post: 08-14-2020, 11:29 PM
  2. samsung s3 touch in not my control
    Last Post: 08-13-2020, 08:06 PM
  3. Replies: 3
    Last Post: 08-13-2020, 12:29 PM
  4. why is my itel a14 stuck in fastboot mode
    Last Post: 08-13-2020, 09:56 AM
  5. Want my weather app back as
    Last Post: 08-13-2020, 02:55 AM
