    I've tried different charging cords and blocks. The charging light is on, so I know power is getting through, but as soon as I unplug it, that light goes out. I can't even get it to turn on. Is there any hope?
    08-18-2020 09:22 PM
  2. mustang7757's Avatar
    Which device? How old is it ? Orginal battery?
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.https://forums.androidcentral.com/sh...d.php?t=409154
    Laura Knotek likes this.
    08-18-2020 09:25 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! What color is the LED notification light when you're charging? Have you already tried letting it charge undisturbed for at least 6 hours before trying to power on by pressing and holding Power for at least 20 seconds?
    08-18-2020 09:37 PM
  4. belodion's Avatar
    A bad battery or something else inside the phone.
    08-19-2020 07:37 AM
  5. PHenry57's Avatar
    I'm have the same issue. The phone was just updated a few days ago, it restarted randomly and now is stuck off. Charging does absolutely nothing. No LED lights show up when plugged in, and no method of powering on the device works. It seems like its bricked.
    08-30-2020 07:51 PM
  6. mustang7757's Avatar
    Hi, welcome!
    Which phone do you have ?
    08-30-2020 08:19 PM
  7. Laura Knotek's Avatar
    How long did you keep it on the charger? Try keeping it on the charger for at least 12 hours and see if it turns on again.
    mustang7757 likes this.
    08-30-2020 08:20 PM
  8. PHenry57's Avatar
    Its a Samsung S20+
    I'm letting it charge overnight with the stock charger and cable
    08-30-2020 08:44 PM
  9. Laura Knotek's Avatar
    Its a Samsung S20+
    If it doesn't work, you can submit a warranty claim since it's under warranty.
    08-30-2020 09:30 PM
  10. B. Diddy's Avatar
    Welcome to Android Central! After letting it charge undisturbed for that duration, try powering on by pressing and holding Power for at least 20 seconds.
    08-30-2020 10:56 PM
  11. PHenry57's Avatar
    After charging it for almost 24 hour, it still did not power on. I brought it to a Samsung service dealer for them to check for any issues with the battery or charge port. Hopefully it isn't the mobo. Fingers crossed.
    08-31-2020 05:59 PM
  12. mustang7757's Avatar
    Ok good, let us know!
    08-31-2020 06:07 PM
  1. Does Sim come with phone bought from Samsung?
    By FredRickJames1970 in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 08-19-2020, 10:22 AM
  2. Charging dock/station
    By arab305 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 08-19-2020, 03:23 AM
  3. Need some help with my phone
    Last Post: 08-18-2020, 08:31 PM
  4. Trying to use "lg mobile switch app" to transfer all my data
    Last Post: 08-18-2020, 07:48 PM
  5. Replies: 2
    Last Post: 08-18-2020, 07:22 PM
