1. elpatho's Avatar
    Phone battery and CPU overheats in minutes while doing nothing and it has weird problem with audio
    CPU and battery temperature (according to some apps) climb up to high temperatures in no time. Whole phone is super hot and laggy few minutes after starting it up.
    It has probably something to do with jack and audio. When I try to play sounds from speaker, the phone just lags and start to heat up even more and is unusable. When I connect headphones, the audio plays but the phone start doing weird things like randomly going to silent mode and works only left headphone. It started randomly one day without any prior problems (expect the fact that sometimes my headphones put my phone on silent mode and the buttons for pause and play on them stopped working).
    Its not software related because I did factory reset, uninstalled everything, disabled wifi and phone services and even installed new OS and the problem is the same every time.
    I have Nexus 5X. Its 5 years old, but its still in great shape (or it was before the incident) so I would like to fix it rather than buying new phone.
    08-29-2020 05:24 AM
  2. Galactic Zoo's Avatar
    What incident? Water damage?
    08-29-2020 06:08 AM
  3. elpatho's Avatar
    It was badly worded sorry. By incident I meant that it happened one day out of nowhere. But I connected speakers to the phone and the phone restarted. Later that day it started to do the things I mentioned. That day I thought its nothing, but with issues with the audio I think it can be related somehow.
    08-29-2020 06:16 AM
  4. Galactic Zoo's Avatar
    We're the speakers you connected to powered?
    08-29-2020 07:32 AM
  5. elpatho's Avatar
    Yes, they were large speakers with amplifier. But I connected it through ordinary jack cable. Also I made a mistake and inserted the cable in the output hole instead input of the amplifier. But other person did the same thing and it didnt do anything to his phone. Or computer.
    08-29-2020 07:59 AM
  6. mustang7757's Avatar
    Hi, welcome to AC!
    [Changed you to post owner of the thread from guest ]
    08-29-2020 09:47 AM
  7. Galactic Zoo's Avatar
    I'm inclined to agree with your thoughts about the jack. I think it got fried
    mustang7757 likes this.
    08-29-2020 11:25 AM
  8. mustang7757's Avatar
    They probably got lucky , you didn't
    08-29-2020 11:56 AM
  9. elpatho's Avatar
    So is it possible to fix it by changing the jack or is it going to be more complex repair?
    08-29-2020 04:15 PM
  10. Kizzy Catwoman's Avatar
    It may be worth looking at ifixit or jerryrigevergthing on YouTube for a teardown of the nexus 5x if they have one on there. That would show you if the jack is easy to replace or not.
    08-29-2020 05:30 PM
  11. elpatho's Avatar
    But I dont understand how fried jack can do all the overheatings and problems with audio. It sounds like it started there but some more serious problem happened deeper because of that.
    08-30-2020 05:32 AM
  12. B. Diddy's Avatar
    Does the same problem happen if you connect to Bluetooth headphones?
    08-30-2020 01:31 PM
  13. mustang7757's Avatar
    The nexus 5x is easy to take apart, I replaced my battery on mine and USB c port
    08-30-2020 01:35 PM
  14. elpatho's Avatar
    I connected it to the bluetooth speakers and I was unable to start any music. And the phone is still acting crazy and overheats when I try to play anything.
    08-30-2020 02:07 PM
  15. elpatho's Avatar
    Yes, but I rather meant that if its solely the jacks fault or is it possible that something more is fried. I googled a little bit and this kind of problem is accompanied with the damaging of the logic board. So I would not be able to fix it by my self I dont have the right tools, but it is even worth it to pay for the repair from professional?
    08-30-2020 02:10 PM
  16. B. Diddy's Avatar
    The Nexus 5X, like other LG phones of that era, was somewhat notorious for motherboard failures, so the accidental plugging in could've been coincidental.
    08-30-2020 02:12 PM
  17. mustang7757's Avatar
    You would need tools if you don't have them, then locate parts , try get a quote from local phone repair center see if its worth it
    08-30-2020 02:13 PM
  1. 'Network permission' notifications for apps in Android 10 - turning off
    Last Post: 09-06-2020, 01:02 AM
  2. Overlap of screen Samsung S9 with 2 different times visible
    Last Post: 08-29-2020, 01:57 PM
  3. i want an app and website for my small e-commerce business
    By LooKMe tech in forum Developers Lounge
    Last Post: 08-29-2020, 01:27 PM
  4. How do I remove this pop up "blocked by iwawa" on my kids tab
    Last Post: 08-29-2020, 04:29 AM
