Is it the factory data reset in backup and reset settings or the one where you hold down the power and volume down button? I'm not sure about this.
And are there any tips before I proceed on resetting my phone?
Is it ideal to bypass frp? Someone told me it takes about 3 days to finish if you proceed the normal way. True?
