    This same fault has been asked before for Samsung mobiles, unfortunately the solutions did not work for Huawei, please help us
    09-21-2020 06:55 AM
  2. mustang7757's Avatar
    You want change voice note app notification tone? This is Samsung Notes app you trying port over to Huawei?
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply
    https://forums.androidcentral.com/sh...d.php?t=409154
    09-21-2020 08:46 AM
  3. Surfies's Avatar
    Hi Mustang7757, thanks for prompt answer, the problem, when we receive voice notes on whatsapp the default ring tone and buzzer goes on and mix with the message for the duration of the message, the phones are Huawei p20 lite, and y7 2019 pro.
    09-21-2020 10:27 AM
  4. mustang7757's Avatar
    Hi, welcome!
    Try clearing cache and force stop whattapp
    09-21-2020 10:50 AM
  5. B. Diddy's Avatar
    Welcome to Android Central! Can you change the notification tone for voice notes on WhatsApp to something very short?
    09-21-2020 12:13 PM
  1. Its about my my phone..not working with earpiece on calls
    Last Post: 09-21-2020, 08:35 PM
  2. How to stop someone from hacking vcard on Android
    Last Post: 09-21-2020, 08:13 AM
  3. Cannot on my phone only showing unfortunately voice command stopped
    Last Post: 09-21-2020, 12:44 AM
  4. suggested sharing apps and contacts
    Last Post: 09-20-2020, 10:41 PM
  5. Does anyone know
    By sexiboi514 in forum More Motorola Phones
    Last Post: 09-20-2020, 09:16 PM
