    I have the Note 8 and sometimes when I plug my charger in when the battery is low (usually between 10% and 30%) I see the charging light come on but it won't actually charge as I'll come back an hour or 2 later and it'll actually be down 1-2% from when I plugged it in.
    I'll have to plug and unplug it several times and wait 5 minutes or so to see if it goes up before I can comfortably leave it otherwise I won't know. I've tried different chargers/charging wirelessly and I get the same issue. It shows charging but won't actually until I try it several times. I'm assuming this is a battery issue and not the charging port since wireless charging gets the same results?
    Should my next step be just to have the battery replaced?
    10-26-2020 08:06 PM
  2. VidJunky's Avatar
    Wow you've actually done some testing and troubleshooting. Color me impressed. If you've tried different methods, cables and chargers with the same result there is a good chance that it is the battery. The way batteries work is they move electrons from negative to positive and along the way the electron is able to do some work. The most stable charge of a battery is 50% when the negative and positive poles of the battery have an equal amount of electrons. When either pole gets low on electrons it gets harder to push the electrons to the fuller pole. The number of cycles also plays a part and given that your device is over 3 years old it has probably seen quite a few charging cycles which also affects electron flow and capacity.
    If you plan to keep the device I would say that it is probably time to replace the battery. I would recommend that if you plan to replace it, getting a quality battery. I doubt any of them will be very expensive but age affects batteries too and most were probably manufactured around the time the device was released. They haven't seen the charging cycles but sitting without seeing any cycles is almost as bad. By picking a quality battery with better components you're more likely to get the most life for your money.
    If you would like to reply to this thread and receive notifications when others post comments please create an account. This link will help you do that... https://forums.androidcentral.com/as...-new-post.html
    10-26-2020 09:11 PM
  3. mustang7757's Avatar
    Sounds like the battery , download Accu battery app see what the battery capacity at .
    10-26-2020 09:15 PM
  4. Rukbat's Avatar
    Sounds like operator error. You should never drop a lithium battery to lower than 40%. You're destroying the battery.
    Laura Knotek and J Dubbs like this.
    10-29-2020 12:13 PM
  1. Replies: 7
    Last Post: 10-30-2020, 06:28 PM
  2. Why is mms over WiFi only not working?
    By Robert Chinnis in forum General Help and How To
    Last Post: 10-30-2020, 01:53 AM
  3. Why does google assistant (when turned on) mute my notifications?
    By Android Central Question in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 10-29-2020, 09:25 AM
  4. Every time when I try to make a call there pop up : smart call keeps stopping
    Last Post: 10-28-2020, 11:24 PM
  5. The Autonomous SmartDesk 4 is almost here!
    By Michelle Haag in forum Home Office
    Last Post: 10-26-2020, 02:43 PM
