    I have done hard reset on the phone,factory reset and still of 8 gb i can use just 500-600 mb of memory .
    10-26-2020 09:49 PM
  2. VidJunky's Avatar
    This article will help you clean up your device. At the end they recommend a product they sell, I recommend Ccleaner a free app at the Play Store. Otherwise the tips are good... https://www.syncios.com/android/clea...r-storage.html
    If you would like to reply to this thread and receive notifications when others leave comments please register an account. This link will help you do that... https://forums.androidcentral.com/as...-new-post.html
    10-26-2020 10:25 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! After you reset and then set the phone back up again, is the phone automatically reinstalling your previous apps? Remember that an 8 GB phone only has about 3 GB or so available to the user, since about 5 GB are used up by the OS and any bloatware. If you're reinstalling apps after the reset, that can quickly use up the small amount of storage you have.
    Do yourself a favor and upgrade to a more modern phone with at least 32 GB of internal storage. There are plenty of inexpensive options.
    10-28-2020 11:22 PM
  4. Rukbat's Avatar
    Install a terminal app, like Terminal Emulator for Android. Run it and issue the command
    df
    Look for a line ending in emulated or sdcard. (It might be easier in landscape mode.) That line shows all the storage you can access. The rest of it is in partitions for the system, you can't use it. I'm guessing that the sdcard partition has 1000000 1k blocks (the first column) or less. That would be 1GB. (Scroll up if you don't see the column headings.)
    when you're done, issue the
    exit
    command, or the terminal app will keep running.
    10-29-2020 12:37 PM
  1. I can't open my file explorer anymore
    Last Post: 10-28-2020, 11:25 PM
  2. How can i get to recovery mode in my Emporio Armani smartwatch?
    By Shlomiaba in forum Android Wear / Wear OS
    Last Post: 10-27-2020, 12:08 PM
  3. App folders not transferring, help!
    By dataguy2145 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 10-26-2020, 04:10 PM
  4. How can I get my old facebook messenger chat bubbles back?
    Last Post: 10-26-2020, 01:36 PM
