A Android Central Question Nov 13, 2020 #1 Outta nowhere my phone says unfortunately android systems process acore has stopped. And sometimes will dial *22899 by itself then go to busy signal!! How do I fix it?
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,166 4,262 113 Visit site Nov 13, 2020 #2 Welcome to Android Central! This is a fairly old problem -- see if this thread helps: https://forums.androidcentral.com/t...se-android-process-acore-stopped-working.html Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/ask-question/409154-join-android-central-community.html Upvote 0 Downvote
