    Outta nowhere my phone says unfortunately android systems process acore has stopped. And sometimes will dial *22899 by itself then go to busy signal!! How do I fix it?
    11-13-2020 11:15 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! This is a fairly old problem -- see if this thread helps: https://forums.androidcentral.com/t-...d-working.html
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    Laura Knotek likes this.
    11-13-2020 11:21 AM
  1. [13/NOV/20] ZTKA 4th Android 11 Beta for Global S20's + December Security patch!
    By ironass in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 11-16-2020, 12:15 PM
  2. how to upgrade android 8 to android 9 onida uic 43 TV
    By Android Central Question in forum Android TV
    Last Post: 11-13-2020, 11:42 AM
  3. where is the 'Move apps to SD card on Moto G 2ND GEN 4g PHONE?'
    Last Post: 11-13-2020, 11:40 AM
  4. Android auto weather not displaying correctly
    By Robert Cockerell in forum Android Auto
    Last Post: 11-13-2020, 09:06 AM
  5. Android auto weather not displaying correctly
    By Robert Cockerell in forum Ask a Question
    Last Post: 11-13-2020, 09:03 AM
