    I just my new Poco X3 and I usually do tweaks before using it, so I enable dark mode disable the animations, update the software to the latest, disable pretty much all of the background processes, disable vibrations and other haptic feedbacks, and the phone comes with the 120hz but it has options for you to consider when saving battery and that is the 60hz so i decided to stick with it. Im not really into games or hard user, i only use my phone in social media and texting i dont even use my camera, XD. I hope someone can help me at this im worried that maybe one day getting out of the town and having a long ride and still having this problem is really a problem
    12-23-2020 10:12 AM
  2. belodion's Avatar
    What do your battery usage stats indicate? https://forums.androidcentral.com/as...community.html
    12-23-2020 10:21 AM
  3. Paul Lawrence Porlares Castilla's Avatar
    only screen has the greatest percentage of eating my battery and the rest of my apps only used maybe 2-3%
    belodion likes this.
    12-23-2020 10:27 AM
  4. B. Diddy's Avatar
    Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which may show Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    12-23-2020 01:06 PM
  5. belodion's Avatar
    Problem solved?
    12-30-2020 12:05 PM
  1. Why does my whatsapp call drop when my screenlock is automatically activated (S20 ultra)?
    By Android Central Question in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 12-26-2020, 05:49 PM
  2. How can i change the display on my note 9 shortcut incons from a column to a circular setup
    By Android Central Question in forum Samsung Galaxy Note 9
    Last Post: 12-24-2020, 12:24 PM
  3. Whats wrong with my phone??
    Last Post: 12-24-2020, 05:52 AM
  4. Why does metro pcs open up with chrome?
    Last Post: 12-23-2020, 01:20 PM
  5. Lastnight i went to bed my facebook icon was thete now its not
    Last Post: 12-23-2020, 08:21 AM
