    Hi,
    I have a Redmi Note 6 Pro phone on Mint Mobile. Starting about a month ago, my phone suddenly stopped receiving incoming calls. Any incoming calls, the phone will not ring and calls will go to my voicemail. Making outgoing calls works perfectly. Texting works perfectly however. Data and signal is good, 4G LTE data is fine and works perfectly. Wifi calling works perfectly. Just not able to receive incoming calls. And strangely, this only happens in the area I live in. Once I venture out a few miles of where I live, even if I go across town, the problem goes away and I can receive incoming calls fine. Once I return home or into my neighborhood, problem returns. This problem only started some time a month ago. I tried placing my sim card on several other phones. It has the same problem on two other older phones I tried. But the problem goes away on another phone which is a bit newer. I took my phone to my phone plan dealer and they were clueless at the problem.
    Any help and suggestions appreciated. Thank you.
    04-12-2021 01:40 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which carrier do you have? Are you relying primarily on wi-fi calling when you're at home, or the phone's own mobile signal?
    Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/as...community.html
    04-12-2021 12:23 PM
  1. Why can't I directly reply to messages on Instagram?
    By Nagget boi in forum Samsung Galaxy S9 & S9+
    Last Post: 10-10-2021, 11:26 AM
  2. How can enable sound and calling that was disabled by device policy
    Last Post: 04-11-2021, 05:46 PM
  3. Suddenly can't see podcast files!
    By soshann in forum Ask a Question
    Last Post: 04-11-2021, 11:30 AM
  4. Replies: 2
    Last Post: 04-11-2021, 11:24 AM
  5. Can I use multi-user to isolate apps?
    Last Post: 04-10-2021, 11:57 PM
