1. Gob Shite's Avatar
    How do I record stereo audio from a record player RCA/phono sockets to usb socket on Huawei mate 20 pro?
    Solved. For anyone with the same challenge.
    Buy a stereo phono to 3.5 TRRS jack which carries headphone AND MICROPHONE
    How do I record stereo audio from a record player RCA/phono sockets-s-l400.jpg
    Buy a 3.5 jack microphone splitter
    How do I record stereo audio from a record player RCA/phono sockets-headphone-splitter-aud-mic-1822.jpg
    Buy a 3.5 jack to USB C
    Download Open Camera - This has a video setting to enable recording audio from an external microphone
    Voila:
    06-21-2021 07:34 AM
  2. VidJunky's Avatar
    I found this with a quick shopping search... https://www.googleadservices.com/pag...gQIARBL&adurl=
    Alternatively there are other analog to digital products out there that do similar stuff. Depends on how much you want to spend. If you have an older PC they often have RCA inputs, most of the ones that don't still have AUX (microphone) type connections as do many laptops. I can usually find double male 3.5mm cables at my local Big Lots for $3 to $8.
    Laura Knotek likes this.
    07-01-2021 11:48 PM
  3. B. Diddy's Avatar
    Your link didn't show up -- can you edit the post or reply with the link?
    VidJunky likes this.
    07-02-2021 12:30 AM
  4. B. Diddy's Avatar
    Another option might be to connect a Bluetooth transmitter to the record player, and then use an app like one of these to record an MP3 from the Bluetooth input: https://www.androidauthority.com/bes...ndroid-615332/
    07-02-2021 12:31 AM
  5. Mooncatt's Avatar
    I already tried to answer this in your other thread of the same topic.
    https://forums.androidcentral.com/sh....php?t=1026533
    VidJunky and Laura Knotek like this.
    07-02-2021 12:37 AM
  6. VidJunky's Avatar
    Not sure why it wouldn't work for you but I've been there too. Anyway you can see the link landing in the image, it was only meant as starting point.
    B. Diddy and Laura Knotek like this.
    07-02-2021 12:58 AM
  7. Gob Shite's Avatar
    Voila:
    Laura Knotek and B. Diddy like this.
    07-02-2021 02:06 AM
  8. B. Diddy's Avatar
    Awesome, thanks for sharing your solution!
    07-02-2021 06:03 PM
  9. spARTacus's Avatar
    Those ones with the yellow ends I think are supposed to be for video.
    07-02-2021 09:44 PM
  1. Call Recorder by Skvalex isn't working on Android 11
    By umby75fg in forum OnePlus 7 & OnePlus 7 Pro
    Last Post: 06-24-2021, 05:50 PM
  2. How do I unlock a qlink phone
    Last Post: 06-21-2021, 01:28 PM
  3. Stuck on boot loop and downloading do not turn off target
    Last Post: 06-21-2021, 11:06 AM
  4. How is the Galaxy Tab S6 Lite?
    By JnEricsonx in forum General News & Discussion
    Last Post: 06-20-2021, 08:58 PM
  5. How do i fix my navigation bar
    Last Post: 06-20-2021, 06:44 PM
