So i'm using this chinese phone i bought in france it's called ECHO MAX and it has MT6735 , i can't find original rom or scatter files for it over the internet , i was trying to install TWRP but it kept restarting into the normal one, i needed to change the rom because it has a virus here is full info on the phone :
Taille de la diagonale : 5.5"
Résolution du capteur : 8 mégapixels
Capacité de la batterie : 2700 mAh
RAM : 1 Go
Génération à haut débit mobile : 4G
Système d'exploitation : Android 6.0
07-10-2021 02:39 PM
