    I have a Samsung a20, about 18 months old, which works nominally 90% of the time; however, about once every other week when it gets to low battery (~30%) it will begin to discharge at a high rate, dropping to low or zero percent in about 15 minutes. This usually happens when I'm using a more battery intensive app, specifically pokemon go. I have screenshots of the battery drain but i cant seem to paste them into here, they look like normal battery drain until a sharp drop. Also i should mention ive heard this could be a sign of a failing battery, but since its a relatively new phone and it only happens infrequently i want to check its not something im doing. I have the phone in battery saver, and device care says theres nothing wrong. Thanks for your help.
    07-17-2021 01:06 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! You need to register in order to post images: Join the Android Central Community! - Android Forums at AndroidCentral.com
    18 months isn't exactly "new" -- it depends on how you treat the battery. It can be helpful to install Accubattery and use that apps Battery Health feature to determine how your battery is doing.
    07-17-2021 02:18 AM
  3. mustang7757's Avatar
    Playing intensive games will cause battery degradation quicker. Probably will need battery replacement soon .
    07-17-2021 10:35 AM
  1. My S9+ battery life is near its end
    By methodman89 in forum Ask a Question
    Last Post: 07-20-2021, 08:44 AM
  2. Pixel 3 battery charging
    By IMANUT46 in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 07-15-2021, 02:44 PM
  3. Battery percentage on home screen.
    Last Post: 07-15-2021, 12:14 PM
  4. Why is my phone screen showing a battery icon going in and out
    Last Post: 07-13-2021, 01:47 AM
  5. Why gboard is draining my phone battery fast?
    Last Post: 07-09-2021, 01:53 PM
