    Hi Guys. I am trying to use a Type C Mic on my note 9.
    When I record audio on the voice recorder app the Type C mic works perfectly.
    When I try to record a video using the Note 9 camera, the phone picks the audio from the internal mic, instead of the Type C; even though when I start to record the phone says "recording audio from USD mic"
    I tried restarting but the problem continues
    07-21-2021 01:12 PM
  2. mustang7757's Avatar
    When you connect the external mic does anything pop up on the notification panel ?
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply
    https://forums.androidcentral.com/sh...d.php?t=409154
    07-21-2021 02:28 PM
  3. adventurousl's Avatar
    Hi, thanks for responding. I only got the notification once.
    An important update is this:
    I downloaded an app to record video from my phone, and the mic works well with it.
    The problem is happening only when I try to use the phone's camera to record, which I would prefer to use. When I use the phone's camera grabs the sound from the phone mic, instead of the external Type C. The phone still says "recording audio from external usb mic" but is not doing it
    07-21-2021 06:18 PM
  4. mustang7757's Avatar
    Hi, welcome to AC!
    What about in safe mode?
    07-21-2021 07:50 PM
  5. adventurousl's Avatar
    tried safe mode, but I got the same error
    07-21-2021 10:10 PM
  6. mustang7757's Avatar
    Try another camera app in play store see if it recognize it ?
    07-21-2021 10:20 PM
  7. adventurousl's Avatar
    Hi, thanks for getting back to me.
    I tested two more camera apps and none of them are picking up the sound from the external mic.
    So far the only ones that are picking up the sound of the external mic are the default Voice recorder app, and this more sophisticated app to record video called Cinema FV-5 Lite
    07-22-2021 09:01 AM
  8. mustang7757's Avatar
    Maybe in permission for camera app turn on or off the microphone see if makes a difference?
    07-22-2021 09:35 AM
  9. adventurousl's Avatar
    No, it didn't work
    I changed the permissions and rebooted but nothing
    07-22-2021 12:00 PM
  10. mustang7757's Avatar
    No, it didn't work
    Im out of suggestions
    07-22-2021 12:02 PM
  11. mustang7757's Avatar
    One other thing , go to developer settings and play with usb settings there ?
    07-22-2021 12:11 PM
  1. Galaxy Note 9 Android 10 = WPA3 Wifi compatible?
    By captivedroid in forum Samsung Galaxy Note 9
    Last Post: 07-26-2021, 11:13 AM
  2. Note 8 still camera and video camera on same screen.
    Last Post: 07-21-2021, 02:46 PM
  3. Can i obtain permanently deleted notes was accidentally deleted by mi
    Last Post: 07-21-2021, 02:44 PM
  4. Samsung Notes question
    By joesf in forum Samsung Galaxy S21 & S21+ & S21 Ultra
    Last Post: 07-19-2021, 10:21 PM
  5. Otg problems
    Last Post: 07-18-2021, 09:18 AM
