    Hi Guys,
    I am on the MIUI Version 12.5.8 and I see in the Control Centre there is no quick action/toggle button to control volume on the media playing. is there a way that I can also add the volume control button option to the control centre ?
    09-16-2021 06:36 AM
  2. mustang7757's Avatar
    Check in settings>sounds >anything to toggle use volume button for media?
    When you press the volume button do you see any options or 3 dots to tap to take you to all volume control?
    I'll leave a Link to register so you can communicate here, As a guest account you can only post questions but can't reply
    https://forums.androidcentral.com/sh...d.php?t=409154
    09-16-2021 10:51 AM
  1. Why does google calendar not allow me to select a colour for eac event?
    Last Post: 09-17-2021, 02:55 AM
  2. Why not write in 14 character long contact name
    Last Post: 09-17-2021, 02:51 AM
  3. How to check unknown person photo in face book
    Last Post: 09-16-2021, 02:11 AM
  4. Replies: 1
    Last Post: 09-15-2021, 05:00 PM
  5. Volume panel stuck on
    Last Post: 09-15-2021, 01:59 PM
