    The mic is working just fine, and all apps have permission, but the only app that picks up audio from my mic is the phone app. Nothing else pics up audio. I cant use google assistant, or tune my guitar .I have checked permissions, and everything is how it should be.
    09-21-2021 10:50 AM
  2. mustang7757's Avatar
    Which device?
    Have you tried safe mode ?
    I'll leave a Link to register so you can communicate here, As a guest account you can only post questions but can't reply
    https://forums.androidcentral.com/sh...d.php?t=409154
    09-21-2021 11:19 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Are you using a case? Make sure the secondary mic (at the top of the phone) isn't blocked, and is clear of any debris. Remember that many apps will use the secondary mic rather than the primary mic (which is at the bottom of the phone), so if the secondary mic is blocked or faulty, that could cause your problem.
    09-21-2021 12:22 PM
  4. Mike Dee's Avatar
    Thats what I was thinking but wasn't really sure
    B. Diddy likes this.
    09-21-2021 09:13 PM
  5. ProXplode2468's Avatar
    HI. Im the original poster. Its a samsung A70. I have tried with and without a case. There is no debris in the microphones
    09-22-2021 12:56 AM
  6. B. Diddy's Avatar
    Try testing the microphones using the Samsung Members app.
    09-22-2021 01:16 AM
  7. ProXplode2468's Avatar
    Ive done this now. The bottom microphone is very quiet, the top one works just fine
    09-22-2021 02:07 AM
  8. B. Diddy's Avatar
    That's surprising, I would've thought it'd be the other way around. When you speak to people on the phone (using the primary mic, not speakerphone), do people ever complain that you sound soft or muffled?
    Is the phone still under warranty?
    09-22-2021 02:21 AM
  9. mustang7757's Avatar
    HI welcome to AC !
    You have a app to tune your guitar , try uninstalling that .
    Also if you didn't try restart the device.
    09-22-2021 02:33 AM
  10. ProXplode2468's Avatar
    It is not. It arrived broken, and the company I bought it from refused to repair it when it was under warranty. I got it repaired just when it was out of warranty by an external business.
    and no. People hear me perfectly when I am talking on the phone. My Dad is hard of hearing, and hears me perfectly.
    09-22-2021 02:41 AM
  11. ProXplode2468's Avatar
    HI welcome to AC !
    I have restarted the phone.
    Do you think its the tuning app causing the issue?
    09-22-2021 02:41 AM
  12. mustang7757's Avatar
    Lets find out by Uninstalling it , then do restart afterwards
    09-22-2021 02:42 AM
  13. ProXplode2468's Avatar
    I have done that, and completed a test of the samsung members app. The bottom mic is still extremely quiet
    09-22-2021 03:04 AM
  14. mustang7757's Avatar
    So you mentioned it was previously repaired for this same reason?
    09-22-2021 03:07 AM
  15. ProXplode2468's Avatar
    No. Sorry for the confusion. When I received the phone originally, the motherboard was damaged, and not attached properly, causing it not to charge. This was however, recently fully repaired by a credible local business. It wasnt to do with the microphone
    mustang7757 likes this.
    09-22-2021 03:09 AM
  16. mustang7757's Avatar
    Ok thanks , im thinking it got damaged but couple other questions , do you mess with developer settings or accessibility on the device?
    09-22-2021 03:12 AM
  17. ProXplode2468's Avatar
    I do not know what that is, so I have not. However, because this used to be my dads phone, before I got it repaired, there is a chance that he messed around with the accessibility settings. Could this be it?
    09-22-2021 03:15 AM
  18. mustang7757's Avatar
    You should be able to reset accessibility if anything was touched by going to settings>general management>reset >reset accessibility can also fgve reset settings afterwards a try
    09-22-2021 03:17 AM
  19. ProXplode2468's Avatar
    I reset the accessibility settings, and I am having the same issues
    09-22-2021 03:30 AM
  20. mustang7757's Avatar
    Its looking more like your microphone needs replacement, last thing is factory reset but thats not 100 percent.
    09-22-2021 03:35 AM
  21. ProXplode2468's Avatar
    I see. Okay, thank you for your help!
    09-22-2021 03:36 AM
  22. mustang7757's Avatar
    Your welcome!
    09-22-2021 03:39 AM
  1. Odd phone behavior
    By amyf27 in forum Samsung Galaxy S21 & S21+ & S21 Ultra
    Last Post: 09-22-2021, 05:36 PM
  2. Can i recover all my data from corrupted sd card in Android phone?
    Last Post: 09-21-2021, 12:21 PM
  3. Replies: 1
    Last Post: 09-21-2021, 12:08 PM
  4. how long will this phone last?
    By preppystud in forum Google Pixel & Pixel XL
    Last Post: 09-21-2021, 06:54 AM
  5. Nova launcher - Swipe up to search apps?
    Last Post: 09-20-2021, 10:34 PM
