1. Unkown0992's Avatar
    I need to power off my phone i click the power button its dosen't work after a 1 to 5 minutes the power off icon is showing then i click it then it shut down after shutdown it restart automaticly then i tried to shut down it restart again so i think my power button is broken or something that i click it help me pls i need to charge my phone!.
    04-22-2022 02:26 AM
  2. B. Diddy's Avatar
    Try cleaning the power button by swabbing its edges with plenty of 99% rubbing alcohol, in case there's some residue stuck in there that's making the button stick.
    04-22-2022 03:21 AM
  3. mustang7757's Avatar
    Also remove your case if you have one
    B. Diddy likes this.
    04-22-2022 10:32 AM
  1. Has my Lenovo m8 Android 10 Chrome tablet been infiltrated?
    Last Post: 05-01-2022, 10:08 PM
  2. Android fb app suddenly says i have no pictures in my gallery??
    Last Post: 04-24-2022, 04:55 PM
  3. Text messages total size in use
    By Gary_Berg in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 04-22-2022, 05:56 PM
  4. How can I make a phone as simple as possible?
    Last Post: 04-21-2022, 07:23 PM
  5. Why cant i change my keyboard sound
    Last Post: 04-21-2022, 04:46 PM
