    Hi! I recently had to replace the screen to my Motorola Moto Z3 by hand at home. I've done this before as the screen was broken and replaced once before, and this is the second time. It worked even with the broken screen. I used Google Assistant if I needed to check the time and such. Then, I held down the power button to turn it off. After replacing the screen, now the phone will not turn on. It does feel warm when plugged in, however. Anybody know what could be the issue and provide some solutions?
    07-30-2022 07:35 PM
  2. mustang7757's Avatar
    Try opening it up and see if anything got disconnected if not then need a professional repair shop.
    If you have further questions
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply
    https://forums.androidcentral.com/as...community.html
    Sent from my SM-S908U1 using AC Forums mobile app
    07-30-2022 08:01 PM
  3. Ben xfg's Avatar
    Try unplugging the battery for a bit.
    07-30-2022 08:05 PM
