A
AC Question
So the battery will charge to max 81%, even after overnight charge, when it reaches ~20% it will start to free fall, no matter what the use, it can only be charged when the phone is off, when it's on it actually acceleratingly starts to go down.
Then it's definitely empty, you can't turn the phone on. I tried calibrating and switching charger and cable but it doesn't change.
I think I've got a faulty battery but can't be sure if it's not software problem and I'd like some second opinions as I'm new to android.
I have a 2800mAh at 3.7V, 5" screen at min. brightness,3g off,no mobile internet and apps,android 4.2
https://www.dropbox.com/s/751bjyft9klvnh9/Screenshot_2014-06-30-10-02-28.png , rising and flat is charging while off
https://www.dropbox.com/s/ev4v14ttm94r74t/Screenshot_2014-06-30-10-02-35.png , voltage
https://www.dropbox.com/s/6xdbsmy8uxkb8on/Screenshot_2014-06-30-10-01-28.png ,android's usage statistics
Thank you for any help
