1. DanishShaikh31's Avatar
    Heyyy...
    I've just got my new galaxy note 3 neo
    N I have a problem with the camera
    The camera load pretty fast but whenver I click the photos, it gives me a processing screen (which a kind of messagebox without buttons)
    That processing screen helds for about 1 second only but its annoying
    Can Anyone help
    Details:
    The problem is specific with "No effects" option
    While with other options like "greyscale" "sepia" "vignette" etc.. , the processing screen does not appear
    07-06-2014 04:07 PM
  2. Relgoshan's Avatar
    Check if it's in HDR mode. HDR is usually not compatible with color effects.
    07-06-2014 04:15 PM
  3. anon8380037's Avatar
    Smart Stabilisation in the camera settings usually does this but not in ideal daylight conditions. It will process low light or difficult images only so I leave it set on my regular Note 3.
    DanishShaikh31 and Relgoshan like this.
    07-06-2014 04:33 PM
  4. DanishShaikh31's Avatar
    Thank u soooooo much for the help...
    It worked...!!!
    anon8380037 likes this.
    07-07-2014 01:13 AM
  5. Relgoshan's Avatar
    So that's how it works? Go figure why I didn't notice any difference when I tried it out.
    07-07-2014 11:27 AM
  6. anon8380037's Avatar
    I got it third hand from our camera guru's. I think it might play up on some phones though, and work all the time when it should be automatic.
    Relgoshan likes this.
    07-07-2014 11:35 AM
  7. Abhijeet Tilekar's Avatar
    same problem here too..
    i just reset it but doesnt solve the problem
    11-21-2014 02:26 AM
  1. Don't have permission on Galaxy Tab to install Netflix app
    Last Post: 09-07-2014, 02:50 AM
  2. Replies: 1
    Last Post: 09-04-2014, 01:37 AM
  3. Battery draining fast! On S5 and Gear 2 Neo
    By Vanessa0831 in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 08-04-2014, 12:25 PM
  4. Samsung Galaxy S4 Active not turning on
    Last Post: 07-25-2014, 09:25 PM
  5. My cousin's galaxy note 3 got stolen
    By OmarVlogable in forum Ask a Question
    Last Post: 07-06-2014, 02:03 PM
