Re: Battrey disconnected
Welcome to Android Central! Remove the battery and check all of the connections for dirt or grime. Place the battery flat on a table and try to spin it--if it spins freely, it's bulging in the middle, which suggests a failing battery. If it doesn't spin, put it back in, and make sure it sits snugly--maybe it has become loose, and intermittently loses contact.
