A
AC Question
Hi,
I have a samsung s5 and a moto e. Both exhibit the following issue.
When I turn on taptalk, I have to select the button then double tap to activate it, which is awesome. Except that due to a movement disorder I cannot double tap quick enough. Is there a way I can customise the time between taps that registers a double tap event so that it recognises my slow double tap?
Andrew
Andrew
