hi i have Samsung galaxy s advance. and i problem is that i have to press power button hardly to turn the screen on off and for other function is there any way i can make it soft like before??
There might be something stuck in the power button. A good cleaning might solve the problem. Another thing you can do is to try to clean it with an alcohol (after turning your phone off and taking the battery out) or give it to a professional for service
