hi there my s3 wont charge from a cig lighter.and my tecknet power pack any more.itwill only charge from the wall .ive replaced the battery, but that hasnt helped.baffled. it suddenly started to play up.is my phone broke
Printable View
Welcome to Android Central! Are you using the same USB cable to connect to the car charger or the power pack as you do to the wall charger? Or are they separate cables?
