The screen colors have changed on my Samsung Note 3 and my photos are showing as negatives, can anyone help me fix this?
A
AC Question
On my Samsung Note 3, the screen colours have changed and photos are like negatives
My start screen color has changed to blue and the next screen background is now orange instead of blue. All icons and contact pictures are like negatives. When I reboot the phone comes back with the standard col ours and after about two seconds it reverts to the above strange col ours and negatives. This occurred yesterday when I had the phone on charge.
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Re: On my Samsung Note 3, the screen colours have changed and photos are like negatives
Did you root and install custom screen mods on the device? If you are able to get into the system settings, consider a factory reset (system settings > security > factory reset). See if that helps.
If it doesn't, then it could be hardware related, and you'll need to have the device sent to Samsung for repair or replacement.
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Check Settings/Device/Accessibility/Negative colors (under Vision). You probably have it checked.
KeepItReal
547
It's actually a cool look, lol. It is for battery saving.
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,391
255
83
^^^I think that it's all or nothing.
tarniman1
thanks so much man I know its almost three years later but your posts is still helping people. I never would have probably figured that out on my own. I thinking the worst...hardware related
123dzo
