1. AC Question's Avatar
    Battery indicater shows not taking charge
    11-03-2014 07:21 AM
  2. belodion's Avatar
    There must be a fault in the charger, USB lead, USB port in the phone, battery, or elsewhere.
    Rukbat likes this.
    11-03-2014 08:53 AM
  3. Rukbat's Avatar
    Try a known-good charger, with a known-good cord, plugged into a known-good outlet. (IOW, if it charges your friend's Android, try it in yours.) If that doesn't work, the problem is in the phone.
    If it works, replace parts (charger, cord, outlet it's plugged into) one at a time until you find the one that makes it not charge. Replace that.
    belodion likes this.
    11-03-2014 12:17 PM
  4. belodion's Avatar
    Yes, basically you have to start with the electricity supply, which cannot be assumed to be delivering power - in some countries more than others - and work your way from there. There's a lot in the 'elsewhere' that I mentioned, though some of it, such as no power in the premises, is unlikely.
    11-03-2014 01:03 PM
  1. Turbo Charging vs. Wireless Qi Charging
    By rxgadget in forum Motorola Droid Turbo
    Last Post: 11-08-2014, 09:04 PM
  2. Where to get ORIGINAL battery cover?
    By Skimmt in forum Samsung Galaxy S5
    Last Post: 11-03-2014, 11:11 AM
  3. 21mb update....I took my battery life was not so good....
    By jec11718 in forum Motorola Droid Turbo
    Last Post: 11-03-2014, 02:07 AM
  4. How do I connect my Bluetooth with a Delorme GPS?
    Last Post: 11-03-2014, 01:26 AM
  5. Replies: 0
    Last Post: 11-03-2014, 01:05 AM
