No animation and transition speed option in my Lenovo A606. It has only 3 options on developer options. I want to adjust the speed of animation and transition. Any other way? Thanks!
You can change animation and transition speed (and much more) using a custom launcher, such as Nova. Worth a try. Plenty of information in these forums for how to use it.
Ask if you need help with that.
