Xperia SP multitouch problem?
LoizosAristides
(I don't know if this is the correct forum since I'm new to this site...)
Hey,
I have a problem with my Xperia SP's multitouch ability. Basically when I hold one finger to the screen and then try to tap another one, there's a small delay in recognising the 2nd finger. This means that in order to recognise the 2nd finger, I have to hold the screen for a bit, which makes it impossible to play games like Fifa 14, MC4 or Shadow Fight...
It's weird because I've never had this problem before...it only just started. I've tested this with a moutitouch test app from Play Store.
Apparently it happens right after I open a random game (any game). To fix it I have to restart the phone and not open any app, which is just crazy.
I tried factory reseting, upgrading to a newer version, killing all processes except the needed ones...but nothing worked.
Any ideas?
Thanks in advance :)
simanis1236
