Because if I disable the volume warning with root, unroot, and then update it may brick my phone... How do you change settings and update without bricking your phone?
Printable View
If you make a change that can't be made unless the phone is rooted, the update will probably detect that the phone was rooted and stop trying to update. (You'll get an "update failed" notice.)
