Sony Z1: charging issues
Trying to help a friend reporting these issues with Sony Z1c. All helpful suggestions are appreciated.
-- The indicator LED and the charging icon stay on after removing from either USB or the Sony DK32 charging dock.
-- Enters continuous boot cycle with normal shutdown - only way to stop the cycle (or avoid it completely) is a force shutdown (hold power + volume up).
-- Stamina or Power Save battery modes no longer work - battery drains at same rate as when these are not enabled. It also seems to discharge much faster now than when these issues started.
Attempted several factory resets and Sony software repair on my own and again while on the line with Sony support
