Why is my battery percentage going down while charging?
A
AC Question
why is my batery percentage going down while charging
some people told dat it was a battery problem but i don't blve in dat cozz my bttry lives long only my problem is percntge going dwn while chrging
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,365
110
63
Re: why is my batery percentage going down while charging
If it's going down while charging you might have one of these happening:
1. You are using the wrong charger. If the output isn't high enough, it won't charge.
2. The cable/charger is bad. Try different ones.
3. The USB port on the phone is bad. This is for a professional to repair, or your insurance to replace.
Aquila
Retired Moderator
Feb 24, 2012
15,904
I hate to be a bother on this because English wasn't my first language, but this is one of the rules:
Use Proper Grammar & Spelling - Tiping lyk thz iz n0t kewl. NEITHER IS THIS.
