How do I fix 'unfortunately setting has stoped' ?
A
AC Question
how to fix 'unfortunately setting has stoped' ??
I have a question how to fix unfortunately setting has stoped when I'm turn on accessibility ??
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,736
113
Re: how to fix 'unfortunately setting has stoped' ??
Welcome to Android Central! Which device? Does this happen after a reboot? I would suggest wiping the cache partition, but need to know the device first.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,736
113
iPhone 6 Supercopy, huh? Steve Jobs would not approve.:p
I was talking about clearing the system cache partition, not the individual app caches. I'm not sure if the phone in this video is similar or the same, but it's worth a try. Follow the steps in this video, but instead of selecting Wipe Data/Factory Reset, make sure you select Wipe Cache Partition. When complete, then select Reboot System Now.
https://www.youtube.com/watch?v=TIoW66trzEI
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,594
4,736
113
Hard to tell from that video. If you can post a clear screenshot, maybe we could use Google Translate to figure it out.
wei34
