1. AC Question's Avatar
    The Samsung Neo Gear 2 watch can dial numbers out but does not receive any incoming calls from the Samsung Galaxy S4
    I have tried reinstalling samsung gear and still the same
    01-31-2015 12:05 AM
  2. Mike Seaver's Avatar
    I had the same problem. When I first used the Gear 2 Neo and loaded the GEAR MANAGER on my Note 3 it worked flawlessly. Then about week ago I noticed I was no longer receiving notification of incoming calls. Then I remembered I had been surfing around the GEAR MANAGER on the Note and modified the Notification to limit which apps notified me. I had turned off the Incoming Call feature. You can get to these by going to the GEAR MANAGER on your phone select NOTIFICATIONS and then select MANAGE notifications. This will let you turn on and off notifications for specific apps. Be sure the "Incoming Calls" has a checkmark in the box.
    04-16-2015 09:09 AM
  3. swylly's Avatar
    thanks, year old advice fixes new problem for me on Galaxy 5.
    09-06-2016 08:37 PM
  1. Replies: 2
    Last Post: 12-12-2017, 09:12 AM
  2. Why won't my Samsung Galaxy 10.1 charge?
    Last Post: 01-31-2015, 04:28 AM
  3. Why is my Nexus 5 not charging?
    Last Post: 01-31-2015, 04:26 AM
  4. Replies: 1
    Last Post: 01-30-2015, 11:58 PM
  5. Replies: 0
    Last Post: 01-30-2015, 10:43 PM
