Use
Ringtone Maker (or you can do this in
Audacity on a PC, then copy the file back to the phone, if you want a better wuality ringtone). Open the ringtone file (green arrows on the right). Edit. Menu. Fade and Volume. The volume should be at the middle - 0. Move it all the way to the right. Save the file. It'll probably be distorted, but loud. (If you do it in Audacity you can increase it even more without distortion, but playing it back in the phone may cause distortion because the speaker can't handle the volume.) But in either case you'll hear the phone ring, which is what's important.
