1. AC Question's Avatar
    This is my second intuition and I'm having the same problem. Verizon won't replace it unless I want to pay full retail price for it which is out of the question right now.
    What happens is, sometime it charges, sometimes it won't. I'll have it plugged in and it will say the battery is at 2%. Then I'll unplug it, and the battery will show half full. Then it will drop down to almost dead in a matter of minutes. But then when I plug it back in again, it will say that the battery has 65% (or whatever it feels like showing) life left. then it will slowly go back down to 2% while plugged in.
    If I'm lucky, the battery will sometimes show 100% full and I can get maybe 20 minutes of use out of it. Basically, I can't use it unless it's plugged in. Otherwise, it dies no matter what the true percentage is.
    I hope this makes sense to someone out there, I'm about ready to pull my hair out trying to fix this thing.
    Any help would be appreciated. I've tried doing a hard restore and taking out the battery and letting it sit for a while. So far nothing has worked.
    Please help?
    02-12-2015 11:47 PM
  2. srkmagnus's Avatar
    What phone do you have? It sounds like a battery problem. Have you considered replacing the battery if it's removable?
    02-13-2015 12:05 AM
  3. bendert17's Avatar
    Sorry, I'm new to this forum and thought I was posting in the LG Intuition section. I have the LG Intuition and yes, I've tried replacing the battery and have had no luck. It still does the same thing.
    02-13-2015 12:11 AM
  4. Claude Speed's Avatar
    Battery microcontroller is buggy!
    02-13-2015 05:38 AM
  1. WiFi draining battery
    By weston87 in forum LG G3
    Last Post: 02-13-2015, 09:04 PM
  2. Why is my Galaxy S4 screen fading out?
    Last Post: 02-13-2015, 05:49 PM
  3. Replies: 1
    Last Post: 02-12-2015, 10:38 PM
  4. Replies: 1
    Last Post: 02-12-2015, 10:26 PM
  5. Why won't my phone make or receive calls?
    Last Post: 02-12-2015, 10:24 PM
