1. AC Question's Avatar
    Lately (past 2-3 days) my battery has been draining insanely. I've had this phone (S4) for about 7 months now and have never experienced a drainage until these past 3 days. I have downloaded any new apps or anything of that nature. I always have my screen brightness on the lowest setting and I also always have power saving mode on. I've tried fixing all the settings - and nothing! I believe it to be the recent update, but I'm not sure. Should I buy a new battery? Or are there actual solutions to fix this? Currently it's 7:20 a.m. and my battery is at 43%; I woke up at 7 a.m. and it was at 59%.
    02-14-2015 09:22 AM
  2. leegreg81's Avatar
    You could try wiping your cache.
    It my be that an app is misbehaving due to a problem with a cached file.
    02-14-2015 09:26 AM
  3. Golfdriver97's Avatar
    Try this method for rebooting into recovery to clear the cache partition: http://forums.androidcentral.com/sam...2-s3-tab2.html
    Follow the S3 method.
    02-14-2015 09:42 AM
  1. Can't format or use a 16gb sd card on my galaxy?
    Last Post: 02-14-2015, 04:13 PM
  2. Replies: 1
    Last Post: 02-14-2015, 09:48 AM
  3. my moto g 2 camera is not working after update why?
    Last Post: 02-14-2015, 09:44 AM
  4. Can I use an iTunes card on my Android?
    By Rylee Elwell in forum Ask a Question
    Last Post: 02-14-2015, 09:21 AM
  5. Replies: 0
    Last Post: 02-14-2015, 08:55 AM
