A
AC Question
Samsung Galaxy S5 constant restart and drop wifi connection.
So I have an Samsung Galaxy S5 with AT&T that I have had for about 8 months with no issues. Last week it started constantly connecting and disconnecting to my home wifi then a few days ago it started restarting on its own out of nowhere and goes into a reboot loop where it never goes to the home screen. The only way I can stop it from rebooting is to plug it into the charger, but that seems to only be a temporary fix.
Please Help! I dont know the inner workings of cell phones and the detailed terminology that I have seen on alot of posts, but I am pretty tech savvy and hope with some simple instruction I can fix this on my own. I would like to fix this without having to do a factory reboot if possilbe as well.
Thanks in advance!
Thanks in advance!
