My galaxy s4 wont turn on the power button is jammed...how do i fix it?
A
AC Question
I took the back off and took the battery out cause my phone was glitching or something...but know i cant turn it on, i think my power button is jammed how do i fix it..?
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
The button doesn't move in when you press it? You can try gently prying one end up with a wooden toothpick. (If the toothpick breaks you're applying more pressure than it should take if it's just jammed.) If that doesn't work it's going to take a trip to the repair shop.
akbarramadhani12
