How do I fix my Samsung device could not to do normal boot?
A
AC Question
how to fix my samsung device "could not to do normal boot
After root it with odin its stuck in odin/download mode i cannot reboot it i am researching in couple hours still no step by step solution i will keep my patience for the answer
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Re: how to fix my samsung device "could not to do normal boot
Flash the stock ROM with Odin (look on SamMobile Firmwares for a ROM for your particular model), then make sure the rooting method you use is for the particular phone, for the particular version of Android.
