1. AC Question's Avatar
    I have a Samsung cell phone that doesn't charge well anymore. I bought a new battery and still..If the charger is not adjusted very carefully, it won't charge at all. Can it be fixed?
    03-03-2015 08:24 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It's not the battery--it's either the charge port or the charging cable's microUSB plug. Have you tried a different cable? If that also doesn't work, then it's the port. You can bring it to a repair shop to get the port replaced.
    03-03-2015 10:21 PM
  1. How to UNDO a factory reset?
    By Allison Peters in forum Ask a Question
    Last Post: 07-01-2016, 06:18 PM
  2. Replies: 4
    Last Post: 03-04-2015, 10:09 AM
  3. Battery life and apps
    By mbabee in forum Samsung Galaxy Note 4
    Last Post: 03-04-2015, 09:10 AM
  4. How can I get my Samsung Galaxy Tab 7 to hook up to my router?
    By Walter Brannen in forum Samsung Galaxy Tab 2 10.1
    Last Post: 03-03-2015, 10:22 PM
