A
AC Question
I decided to test to water resistant ability of my phone so I filled my sink with water and left it there for a few seconds (I know its rated for up to 30 minutes but I did not have the courage to let it sit for that long). The only issue I have is that the back speaker is muffled now-- is this to be expected? Usually how long should it take before it gets back to normal? The other concern I have is that when I removed the rear cover I noticed that there was some water present outside the rubber seal area but no water entered past the rubber seal. Is this normal ? Or should the inside remaincompletely dry?
