Why won't my Karbonn Sparkle V won't start after installing CWM using ADB.?
A
AC Question
My Karbonn Sparkle V won't start after installing CWM using ADB.
Hello reader. First of all thank you for taking your time. I recently decided to root my Android One Karbonn Sparkle V but I wanted to install ClockWorkMod first. I installed it on my phone using ADB. When I put the battery in the phone it says OEM unlocked and then the booting logo appears. But it keeps going and going and the phone never starts. Please tell me, is it bricked or not?
Akashymon The Viola Penguin
126
Re: My Karbonn Sparkle V won't start after installing CWM using ADB.
Your phone is in bootloop. If you have a custom recovery, clear the cache. If that doesn't work, try flashing the stock Rom into the phone
Posted From my. Rooted LG G3 (D850) Running Android 5.0.1 Lollipop
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Try Karbonn Sparkle V - XDA Forums for help. (Did you install CWM for that phone, or did you install just any one? If it's not for that phone, that would probably be what's causing the problem. Installing the one for that phone might be all you need.)
akbarramadhani12
