1. AC Question's Avatar
    I've been having a problem lately where the sound on my phone for everything from incoming phone calls, to text notifications, to the system sound is very low, and almost inaudible. Some days it's a normal volume and other days it's not. I went into the system sound settings and raised them all to the highest they can go but I'm still having the problem. I've also checked for a system update and my phone is updated with the most recent version.
    03-25-2015 01:02 AM
  2. B. Diddy's Avatar
    Try booting into Safe Mode, which temporarily disables all 3rd party apps. https://support.t-mobile.com/docs/DOC-11473
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    03-26-2015 01:27 AM
  1. talk back turned on in my mobile and how to turn off it
    Last Post: 03-26-2015, 07:10 AM
  2. my phone wont charge but says it is! battery?
    Last Post: 03-26-2015, 01:28 AM
  3. How do I put my Nexus 5 in quiet mode at night?
    By AC Question in forum Google Nexus 7 Tablet (2012)
    Last Post: 03-25-2015, 04:47 PM
  4. How do I unstick my gallery on my Samsung S2?
    By AC Question in forum Samsung Galaxy S2
    Last Post: 03-25-2015, 04:01 PM
  5. How I can fix kernel panic on an Android tablet?
    By Claude Speed in forum Ask a Question
    Last Post: 03-25-2015, 12:30 AM
