How do I block incoming calls while traveling abroad?
A
AC Question
I'll be traveling in Europe and don't want to be bothered by incoming calls that would be outrageously expensive. Is there a way that I can block them on my S5?
Javier P
Ambassador
Feb 21, 2014
19,480
3
As Rukbat said, aeroplane mode is the best way and you can switch WiFi on & off when you need it. Also, in most countries buying a prepaid SIM card is very cheap and you can use it for local calls or mobile data. For example, right now I'm in Spain using one. Free sim card and 5 euros for 500Mb. More than enough to use with online messages and calls.
ParkerAdams
