I want to use tasker to turn on hotspot on my Note 4 Edge ATT.
I want to use tasker to turn on hotspot on my Note 4 Edge ATT when I enter my car, The trigger is my bluetooth connection. I can create the trigger, but can't figure out how to turn the hotspot feature on as it is 3 or 4 levels down in the settings menu.
Re: I want to use tasker to turn on hotspot on my Note 4 Edge ATT.
Set a task for turning it on. It's in Net/Wifi Tether. Set it to on for that task. Trigger the task with the Bluetooth connection. (I'd also set an exit task to turn it off so you don't have to remember to turn it off when you leave the car.)
